The clutch hub could have failed and stopped driving the trans. The TA direct clutch and one way clutch could have failed (if it was working before, it is less likely to be that). Any main component in the final drive could have failed (usually makes drama in noise and jerking) It could also be stuck in two gears at once (If the engine bogs down when in gear and the clutch let out. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
