Re: Farmall h hydraulic pump removal
Posted by FBH44 on September 09, 2014 at 12:20:45 from (64.85.215.0):
In Reply to: Farmall h hydraulic pump removal posted by Danh on September 08, 2014 at 16:21:44:
For stabilities sake, remove the top fill cap befroe you start any of this, and install a slightly longer pipe nipple and a merchant pipe coupling. [Think it"s 3/4-inch pipe.] As you lower the pump slowly to the ground, install longer and longer nipples and couplings. Keep threading them in, so the pump is always held stable by 3/4" pipe. Works great, pump won"t tilt or pivot, and just reverse the process to re-install.
