Re: kill switch for Farmall Super A
Posted by D beatty on September 09, 2014 at 12:42:58 from (24.12.128.33):
In Reply to: kill switch for Farmall Super A posted by Robert E Anderson on September 09, 2014 at 09:10:44:
The one poled mag. switch can be used only on a mag.. The two poled dist. switch can be used on mag. or dist.. You can use a two pole switch on a mag by hooking one wire from mag to one terminal of switch and ground the other terminal to mounting base of switch . The switch will then do the same thing as a single pole switch. This would work till you find the switch you need.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
