Posted by robert major on September 09, 2014 at 22:12:09 from (216.81.28.98):
In Reply to: Bd154 anti-freeze leak posted by Phil Tibbetts on September 09, 2014 at 17:43:24:
Hi If it was mine I'd do them all. Had a 466 diesel motor here in the shop guy only wanted to do the one leaking bore. I said it was gettin worn it needed new sleeves might as well do it while it's here and apart or minimum pull the other sleeves and do O rings. on removing all the sleeves we found 5 out of 6 cyls had brittle O rings that were starting to break up as well plus pitting so did the rebuild. that has 3 rings a sleeve some where down to 1,that was any good, I supplied a kit for a motor like yours once I think it had 1 or 2 rings a sleeve, was about 20 years ago now. if you find the blocks bad on any cylinders, you had borrowed time anyhow, and if you don't pull them all you could be back there very quickly. when another one starts leaking. if they are the original rings they got a lot of years on and might all follow the first one.. Regards Robert
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
