Re: Dumb question...how to tell if my 48 M is + or - ground?
Posted by old on September 10, 2014 at 14:37:18 from (209.86.226.19):
In Reply to: Dumb question...how to tell if my 48 M is + or - ground? posted by R Weld on September 10, 2014 at 14:24:16:
Alternator or generator??? If an alternator it stands about a 99% chance it is - ground. If you are an old car guy you should be able to tell if it is an alternator or not. By the way if is has an alternator on it and you hooked it up wrong the alternator will smoke so fast you can not pull the cable back off fast enough
