Go through your tool box and take out the three oldest worst small straight slot screwdrivers you own. Then grind them to a sharp chisel point. Now use one every 120 degrees and tap them in sequentially When you get the drum 1/2 inch out then it's a back and forth battle. Use lots of penetrating oil on the shaft.then use all the crowbars, prybars, pullers you got that will move it. A prybar with some wood blocks will work.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
