Re: Dumb question...how to tell if my 48 M is + or - ground?
Posted by Heat Houser on September 10, 2014 at 19:48:12 from (69.66.35.73):
In Reply to: Dumb question...how to tell if my 48 M is + or - ground? posted by R Weld on September 10, 2014 at 14:24:16:
Well, if you want to do it with a digital multi-meter, place the (+) red test lead on the starter post and the (-) black test lead on the tractor frame.
If negative ground the voltage will display as positive voltage. (the net effect is the red lead is connected to the battery + post [thru the cable] and the black to the - post [thru the tractor frame])
If it is displaying negative, the ground is positive. (the net effect is the red lead is connected to the battery - post and the black connected to the +)
Clear as mud, right?
