Re: Dumb question...how to tell if my 48 M is + or - ground?
Posted by ss55 on September 10, 2014 at 22:25:59 from (50.81.112.224):
In Reply to: Dumb question...how to tell if my 48 M is + or - ground? posted by R Weld on September 10, 2014 at 14:24:16:
Your M was originally 6 volt positive ground. 12 Volt negative ground has been around for almost 60 years now. Most all alternators are 12 volt negative ground. Most components except an alternator and an electronic ignition can be converted to either ground. On a 68 year old tractor the best answer might be: what would you like it to be, and then build it to be that way.
