Re: Setting up 2 pt 3 bottom plow
Posted by Harry Klever on September 11, 2014 at 05:21:50 from (65.23.185.129):
In Reply to: Setting up 2 pt 3 bottom plow posted by Farmallmaniac on September 10, 2014 at 08:37:27:
I dont know plow numbers that well, but if it's a 3-14, you should be able to set your furrow wheel all the way in, or until you run out of keyway. Setting a plow is mostly trial and error, make a pass, with someone on the ground walking along side. If u have coulters, for said plow use them, they make the plow pull easier. If your going to plow 6 inches deep, set the coulter to a 3-4 inch depth, and a 1 inch to the left, to take a little more dirt, the last furrow should leave a nice straight wall.
