Re: h4 magneto rotation
Posted by calcubman on September 11, 2014 at 06:58:37 from (71.102.209.206):
In Reply to: Re: h4 magneto rotation posted by Tom Fleming on September 11, 2014 at 03:43:20:
it ends with a "D" so it is a counterclock wise
. i have changed the pawls over , removed the
pin at the 8 oclock position and put it in the
hole at the 4 oclock postion, i will change the
rotor to the "r" , is there anything else.? i
am conserned about the indentations on the
pawls , i suppose i could grind the down and
tack weld a bead on the other side, i think
they are just used as a spacer. i see what you
mean by just buying one clockwise, but i have
invested 200 in this allready and dont want to
put anymore in to it,
