Re: Farmall 666 Diesel Hydraulic Pump removal
Posted by Les Repair on January 02, 2001 at 16:51:46 from (206.28.174.43):
In Reply to: Farmall 666 Diesel Hydraulic Pump removal posted by Lance Feia on January 02, 2001 at 10:09:57:
On the left side of the clutch housing exactly accross from the hydraulic filter is a cast cover with several lines comming from it. Attached to this cover on the inside are the hydraulic pumps. Thats right. There are two pumps stacked together.
Post A Followup
: Re: Re: Farmall 666 Diesel Hydraulic Pump removal
