Re: Dumb question...how to tell if my 48 M is + or - ground?
Posted by jnf on September 11, 2014 at 18:27:17 from (64.111.52.5):
In Reply to: Dumb question...how to tell if my 48 M is + or - ground? posted by R Weld on September 10, 2014 at 14:24:16:
Assuming that your ignition wiring is intact, if the wire connecting the coil to the distributor is attached to the negative terminal of the coil, then it is a negative ground tractor. Vice versa applies.
