Re: 5250 Three Point not working.
Posted by MN Scott on September 12, 2014 at 07:11:21 from (75.121.153.58):
In Reply to: 5250 Three Point not working. posted by Nick U on September 11, 2014 at 08:17:59:
Will it work correctly with the lever? If it does I would suspect a bad controller or a wiring fault. Check your grounds. These tractors are famous for electrical gremlins. Find a factory service manual and start tracing wires. Good Luck!
