Re: Setting up 2 pt 3 bottom plow
Posted by a_lead on September 13, 2014 at 06:12:06 from (69.251.128.123):
In Reply to: Setting up 2 pt 3 bottom plow posted by Farmallmaniac on September 10, 2014 at 08:37:27:
I read this somewhere (on this site) and this may help: with tractor and plow on a level spot, jack up the LH wheel 6" to 8" depending upon plowing dept and set the wheel on blocks. Then adjust the plow accordingly. All bottoms on the level and on the ground.
Edward.
