Re: have to run B with choke
Posted by wayne in mn on September 13, 2014 at 10:52:43 from (97.92.1.19):
In Reply to: have to run B with choke posted by rosedale123 on September 13, 2014 at 10:43:44:
Find a suitable container placing it under the carburetor, turn on the shutoff at the tank, remove the drain plug from the bottom of the float bowl and see if there is a steady pencil size stream of gas for a minute or so.
Do you have an in-line filter? That filter must be for gravity fuel systems, not pressure pump systems.
You may have to remove the sediment bowl from the tank to clean any residue from it. A new gasket is usually needed.
