Re: have to run B with choke
Posted by Janicholson on September 13, 2014 at 12:18:46 from (74.60.94.18):
In Reply to: have to run B with choke posted by rosedale123 on September 13, 2014 at 10:43:44:
The flow should be OK because if the flow was weak, the tractor would die after a brief few seconds of choke. The issue is likely to be the main jet having a bit of trash in it, or the float level is too low. Jim
