Re: have to run B with choke
Posted by charlie M on September 13, 2014 at 16:37:20 from (50.48.230.153):
In Reply to: have to run B with choke posted by rosedale123 on September 13, 2014 at 10:43:44:
If you have good flow through the carb then I would look for leaks in the manifold next. Could be loose connections or a hole rusted through the intake side.
