Re: Farmall 140 transmission gears in a C
Posted by tempola on September 13, 2014 at 18:41:52 from (107.77.80.62):
In Reply to: Farmall 140 transmission gears in a C posted by PretendFarmer on September 12, 2014 at 12:53:17:
yes.
The late 140 first gear is is geared slower.
Also""
If you"re going to put the C in the tractor pulls...a 240 UTILITY ring and pinion set will work on the c and super c gearing down the whole tractor by 11%.
It has to be a utility....not a row crop. the row crop has the same gear set as the C
AT
