Re: What all parts are needed to clone a 450 into a Super MTA?
Posted by D Slater on September 13, 2014 at 18:46:36 from (184.14.168.53):
In Reply to: What all parts are needed to clone a 450 into a Super MTA? posted by R Weld on September 13, 2014 at 15:02:36:
Just to put the sheet metal on you need the radiator and the hydraulic unit under the fuel tank for hydraulics plus the hood and grill. Plus if you use the 450 transmission top cover you need to modify mounting for the hydraulic reservoir and steering post. 450 air cleaner vent hose opening will hit the SMTA hood unless some changes. Several more parts needed to make it look like a SMTA from 10 foot away. Unless the fuel tank, air cleaner and center steering support is changed one look at it is a giveaway its not a SMTA part. Same with the transmission top cover, clutch pedal and several other things.
