Re: What all parts are needed to clone a 450 into a Super MTA?
Posted by burnt-smta on September 14, 2014 at 05:32:59 from (184.21.153.213):
In Reply to: What all parts are needed to clone a 450 into a Super MTA? posted by R Weld on September 13, 2014 at 15:02:36:
their are many hard to find parts that you need to turn that into a smta. the choke rod and throttle rod are longer than a late super m, the transmisson cover and clutch/brake pedals are differnt, ta and pto handle is differnt. if you want to keep live hyds you will need a differnt manifold to bolt to the pump and smta light bar is differnt than the m and sm. radiator,seat, battery box,rearwheels are also differnt. you could easliy spend 600-800 on finding smta hoods when i bet for less than 300 you could find decent 400/450 hoods. you can do what you want with your own tractor but you would be further ahead fixing it up as a 450.
