Re: h4 magneto 180 off
Posted by calcubman on September 14, 2014 at 07:03:33 from (71.102.209.206):
In Reply to: Re: h4 magneto 180 off posted by Nebraska Cowman on September 14, 2014 at 03:45:03:
yes the keyway is at a different degree, i found a h4 mag from a super c and took it apart and set it side by side, and the degree is different. i use d it instead, put it on the B and she fired first crank runs like a charm.. thanks for all the input guys, i learned alot.
