Re: Keeping the carb from freezing when plowing snow.
Posted by pete 23 on September 14, 2014 at 18:18:24 from (74.33.79.62):
In Reply to: Keeping the carb from freezing when plowing snow. posted by chemrhetoric on September 14, 2014 at 18:08:19:
The best solution to that freezing problem in the winter is to make a shroud that encases the outside of the muffler. Run a hose from that directly into the intake of the air cleaner. All later model cars with carburetors used a heat stove off the manifold and directed the warmed dried air into the air cleaner. They of course used a thermostatic shutter control valve so when air was warmer it took in cooler air. This does not mean to draw exhaust into engine, just the heated dried air from around the exterior of the muffler. Some one even sells this unit but I have no idea who it is as most are just locally fabricated.
