Re: Keeping the carb from freezing when plowing snow.
Posted by old on September 14, 2014 at 18:55:28 from (209.86.226.19):
In Reply to: Keeping the carb from freezing when plowing snow. posted by chemrhetoric on September 14, 2014 at 18:08:19:
May sound odd but open up the main jet a half turn of so. When cold you need a richer mixture to run well and carb icing is normal and part of the way atomizing of the gas works. Even in the summer you can have carb icing. That is also why the heater cab that are a tarp over the engine work so well. It keep the engine area warm and the driver warmer
