Re: Keeping the carb from freezing when plowing snow.
Posted by john *.?-!.* cub owner on September 14, 2014 at 19:59:46 from (207.119.203.118):
In Reply to: Keeping the carb from freezing when plowing snow. posted by chemrhetoric on September 14, 2014 at 18:08:19:
Have you drained the carb. to make sure there is not water inside it that is freezing and blocking the fuel flow till the engine heat thaws it again?
