Re: Keeping the carb from freezing when plowing snow.
Posted by gene bender on September 15, 2014 at 05:12:09 from (67.55.226.121):
In Reply to: Keeping the carb from freezing when plowing snow. posted by chemrhetoric on September 14, 2014 at 18:08:19:
The shiels you seen was for the dual fuel systems and would work just fine for you providing the manifold has a boss for it to attach to as those manifolds were made for them. You can make a simple shield to warm the carb . That problem has been around since time your car even did that before fuel injection you just didnt see it. All carbs can get frost due to the weather its not the fuelas it is IN the carb. You mite be better if you used some cardboard in front of the radiator to make the engine run a little warmer so quit worrying about the fuel as airplanes with piston engine have the same problem.
