Re: Keeping the carb from freezing when plowing snow.
Posted by Red Mercury on September 15, 2014 at 07:13:17 from (204.112.21.60):
In Reply to: Keeping the carb from freezing when plowing snow. posted by chemrhetoric on September 14, 2014 at 18:08:19:
I have a 67 Ford truck that will do that for the same reason--it is drawing cold air into the carburetor. The truck has an oil bath air cleaner as well which means that it too does not get heated like a modern vehicle. The carburetor would ice up on the inside when I was rolling down the highway causing the accelerator pedal to stick. I had to either reach down and pull it up by hand or shut the truck off and coast to a stop.
The simplest solution was to add a few ounces of methyl hydrate (gas line antifreeze) to the gas tank each time I filled up in cold weather. No more problems. In your case, I am not sure if it is caused by the moisture in the gas, moisture in the cool air, or both.
