Posted by glennster on September 15, 2014 at 07:55:15 from (162.204.229.223):
In Reply to: H starter posted by RMOMN on September 15, 2014 at 06:49:30:
its possible the bendix is extending too far and jamming against the flywheel. you may need to add a shimming washer on the nose side of the starter. there may be an extra washer on the rear side of the armature shaft, move one to the front.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
