Assuming you have the plows that bolt to the reversed U drawbar. If one point fast hitch, the draft control bar is essential. I used the drawbar plow for years without the draft control bar. Set the drawbar at it's lowest setting using the bolts that are there for adjusting the drawbar height. There is an eccentric bolt in the plow hitch that allows the plow side to side tilt to be adjusted. Tilt should be set so the plow bottom runs level at the depth you want when the tractor wheel is in the furrow. With drawbar at lowest setting and the tilt set correctly, you can plow without the draft control bar. It will take two or three passes to get the plow to go to depth because when you first start there is no furrow for the wheel to run in. If plow runs too deep, adjust with the rear rock shaft and the rear lift chains.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
