Re: Super C distributor
Posted by Owen Aaland on September 15, 2014 at 13:22:56 from (216.47.34.49):
In Reply to: Super C distributor posted by Joshua Rod on September 15, 2014 at 10:12:17:
The gear is held on the distributor shaft with a pin that is riveted in place. I usually just use a piece of the correct size (1/8"?) welding rod for a new pin.
