Re: tree vs super a
Posted by gene bender on September 15, 2014 at 16:14:52 from (67.55.226.121):
In Reply to: tree vs super a posted by henhawk1969 on September 15, 2014 at 15:19:43:
Mite need to cut it into if its bent very much as to remove you need to take the big nut off in the end where the shaft goes then unscrew the shaft out the front. But if the shaft is bent very much it will not go thru the bushing and out the front. You can cut the shaft 6in or so before it goes into the housing and then remove it out the front. You will then need another shaft or get a coupling to refasten back together drill holes to fasten pieces to the shaft. I have some good used ones.
