Posted by S MacKay on September 16, 2014 at 05:34:46 from (174.89.39.82):
Anyone want to walk me backwards through this successful repair?
Super A running rough and hot. Decided the problem was fuel supply and cleaned sediment bowl, elbow screen and switched out carb for recently rebuilt one. After a some tinkering on the ignition side of things I thought to blow out the sediment bowl from the tap. That's where the main problem was.
Anyway I also refurbished the ignition which was not a bad thing to do. The point contact in the distributor was cooked (and I mean cooked) and also there was quite a bit of play in the distributor shaft. Fixed that up.
My lingering question is: why was the contact in the distributor cooked? Could it be because the tractor ran lean for too long or was that problem because of a bad coil (or condenser) and therefore unrelated? Or some other reason?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
