Re: 885 vibration
Posted by Gary Vestal on September 16, 2014 at 06:40:41 from (76.7.201.41):
In Reply to: 885 vibration posted by DeltaRed on September 14, 2014 at 18:08:17:
Quoting Removed, click Modern View to see Thanks Jim, I was told that it had 2 pumps as the lift works fine. The pump sounds as it has air in the sys. The top was taken off to replace a gear in the pto a few months ago,could one of the little O rings got nicked? It worked fine for 3 months of mowing as this tractor is used with a 9 ft brush hog. for 30 plus hrs weekly. Gary
