Re: Farmall H Piston-Sleeve clearance
Posted by JohnG(TX) on September 16, 2014 at 09:41:52 from (71.41.163.14):
In Reply to: Farmall H Piston-Sleeve clearance posted by Janicholson on September 16, 2014 at 09:17:11:
I have a set of used step head pistons and the block I believe they came from. I am wondering if they are worn beyond use, or if I can make a go with them. I can measure the pistons and their corresponding cylinders, but I won't know if the clearances are excessive.
I have Googled piston clearances, and for street vehicles it looks to be around 1- 3 thousands, while marine and air-cooled applications are larger. Agricultural applications may be closer to marine, if not larger.
My question is what would be considered excessive based on the intended use of the tractor, which would be for fun, not heavy ag use.
