Re: IH 584 throttle
Posted by 495man on September 16, 2014 at 16:45:52 from (24.137.107.69):
In Reply to: IH 584 throttle posted by Glenn from calgary on September 15, 2014 at 19:29:52:
If it's a "Canadian market tractor" the factory cab is a SIMS and the throttle etc is identical to the open/rops tractors.
With the right hand door open and the access plate off the side of the cowl (three bolts above the brake pedals) you should see all the linkage for the hand and foot throttle. The cab may block some access.
Seems to me your problem will likely be in there since that is where the two controls link yet operate independent, Tractor may think foot feed is still wide open...
