Posted by RC Brooks on September 16, 2014 at 19:21:58 from (70.198.135.242):
In Reply to: Rusty gas tank posted by cubluvn8n on September 15, 2014 at 17:21:07:
Evapo rust works great... rather pricy for a tank. A couple different things that you can do.
1) Electrolysis. Fill tank with washing soda solution. put a piece of rebar in through the neck into the solution, but isolated from the tank. Hook a battery charge + lead to the tank and - lead to the rebar. Let it run for a couple days.
2) Acid. Either a few gallons of muratic or phosphoric acid into your tank. Top it off with water. Let it sit for a week. The more acid, the less time it takes. Phosphoric acid works better, but you can do it with muratic acid too. Just make sure to wear proper protection and get a bag of baking soda from the feed store to neutralize the solution as you start to drain it. Before you start the process, put a sacrificial petcock where your fuel bowl is and a length of hose to your 20 gallon tote with your baking soda solution so you don't get any on your transmission.
This post was edited by RC Brooks at 19:25:34 09/16/14 2 times.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
