Re: C-153 Cam / Crank Timing Marks
Posted by Owen Aaland on September 17, 2014 at 02:44:05 from (216.47.34.49):
In Reply to: C-153 Cam / Crank Timing Marks posted by gene bender on September 17, 2014 at 02:05:08:
Since I gave several scenarios that can't all possibly apply to this engine, but one of them does.
Without knowing how the other gears are marked I can't tell exactly what applies here.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
