Re: broken bolts tap an die
Posted by Lpakiz Larry on September 17, 2014 at 05:18:26 from (184.61.192.47):
In Reply to: Re: broken bolts tap an die posted by gtractorfan on September 17, 2014 at 04:53:49:
I have found that the spiral-tapered easy-outs do not work very well. They tend to spread the bolt out and jam it tight against whatever the bolt is screwed into. Square easy-outs don't so that.
Actually, the very best easy-out I have ever used is a 6 point "torx" bit. Drill the hole the same size, or slightly smaller, than the "minor" diameter of the torx bit, then drive it in.
