Re: Where do I locate the part # for my M distributor?
Posted by D Slater on September 17, 2014 at 05:20:07 from (184.14.168.53):
In Reply to: Where do I locate the part # for my M distributor? posted by R Weld on September 16, 2014 at 16:05:56:
If its a IH you won't find a part number for the complete assembly on the distributor. Like Owen said there's a code followed by a serial number at the base on most of them. Almost always need the retaining clamps off to see. But since the same unit fits onto a lot of IH tractors the code just tells what tractor or tractors the unit was supposed to be used on.
Looks like YT is using the number for the distributor housing and its usually found on the largest round area below the cap on the outside of the unit.
By the YT description it looks like you want # 1142 for a 12 volt negative ground if its a IH distributor. Didn't see one listed for a 6 volt neg. ground. Could have missed it didn't look to hard.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
