Re: broken bolts tap an die
Posted by dodger42 on September 17, 2014 at 18:35:01 from (76.112.97.194):
In Reply to: broken bolts tap an die posted by dewy on September 17, 2014 at 04:42:27:
The first thing I try, especially if there is any small stub of the bolt sticking above the surface, is place a suitably-sized nut over it, and weld that nut to the stub. The heat probably helps the most-usually they just unscrew with no problems after this.
