Re: IH 354 Won't Start
Posted by Janicholson on September 17, 2014 at 18:48:43 from (74.60.94.18):
In Reply to: IH 354 Won't Start posted by thephantompatriot on September 17, 2014 at 16:49:43:
Three things might be going on, one of which is fixed (points). The most likely is fuel supply from the tank to the carb. It must be clean free running and sanitary. Clean the system till it flows a 1/8th inch stream for at least one minute.
The second issue might be that it is not charging. When running the voltage across the battery should be 14.2 volts or a little more. If less than 12.8, it might not charge enough to keep it running. Jim
