Re: IH 354 Won't Start
Posted by wayne in MN on September 17, 2014 at 19:13:33 from (97.92.1.19):
In Reply to: IH 354 Won't Start posted by thephantompatriot on September 17, 2014 at 16:49:43:
Did you adjust the points correctly? The rubbing block must be on the high point on the cam lobe (maximum gap) when setting. Did you accidentally ground one of the wires inside the distributor?
SO, determine what the reason for no-start is; does the spark jump a 1/4" gap?
IF you have spark, is it timed properly?
IF that checks out; remove the spark plugs & squirt about a spoonful of gas in each cylinder. Replace the plugs & wires & try starting.
This way you can VERIFY what is not working properly.
TEST, DO NOT GUESS!!
Good luck.
