Re: broken bolts tap an die
Posted by NNP on September 18, 2014 at 05:02:07 from (66.66.112.196):
In Reply to: broken bolts tap an die posted by dewy on September 17, 2014 at 04:42:27:
all good advice.
If you are breaking bits, you are
going too fast
pushing too hard
hand isn't rock steady
letting your concentration wander (even for a second)
small hole first
lots of oil
slooow drill speed
(watch a machinist drill press in operation)
and lots and lots of patience. If the bit is exiting chips, it's cutting. pushing harder won't hurry it up, it'll just break.
I wish they made a cheap hand drill that had max torque
at one speed....super slow.
Variable speed trigger...bah..if I wanted fast, I'd use a die-grinder.
I never use any style easy-outs on a tightly rusted broken fastener.
Never made much sense to me. If that good quality bolt just failed, a smaller! diameter whatever driven in will work? not likely
