Posted by mkirsch on September 18, 2014 at 05:14:17 from (72.45.143.81):
In Reply to: IH 354 Won't Start posted by thephantompatriot on September 17, 2014 at 16:49:43:
Have you checked for spark? That's the FIRST thing you should do on a gasoline powered tractor that won't start.
If it won't fire on starting fluid, there is no fire, or it's not happening when it needs to.
Do like your dad showed you on the old push mower when you were a kid. Pull a spark plug, stick the wire back on the plug, and lay the plug against the block. Crank the engine over. You should see a blue flash at regular intervals.
There's no trick to starting a tractor that's been sitting 2.5 months if everything is in good shape.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
