See the raised place on the block below the 10-22-W. Following along the top of that tin cover look at the matching raised place behind the coil in the picture. It would help to know if there is any stamped letters and numbers there. Since the date code in the first pictures looked exactly like a K I made a mistake on some answers. That block was cast in 10-22-1951 and probably was a 6722DJ block before they ground the numbers off and stamped in 6943. If it doesn't have a dipstick hole drilled like the other poster pictured that points to a 6722DJ block originally. If it doesn't have a ID prefix or a serial number stamped in on the flat, engine side of coil, that points to a block sold as a replacement. Unless the end user stamped the block.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
