Posted by mkirsch on September 19, 2014 at 05:01:04 from (72.45.143.81):
In Reply to: 660 cab posted by Dundee on September 18, 2014 at 19:36:35:
You've got a tough row to hoe ahead of you. 660 is not a common tractor. Cabs are not common on tractors of that era.
So, you're looking for an uncommon accessory for an uncommon tractor...
How are your fabrication skills? If you just want "a" cab, you can find cabs out the wazoo at any tractor salvage yard. All you have to do is figure out how to mount them.
One factor you have to keep in mind is that the operator's platform has moved forward on the tractor over the years. A modern cab assumes that the seat is directly above or ahead of the rear axle of the tractor. On older tractors the seat hangs off the back, as far out as over the drawbar. IIRC the 660 seat is still behind the axle.
At some point in time, someone has actually fitted an 86 series cab to a 560, so anything is possible.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
