Posted by D Slater on September 19, 2014 at 05:31:35 from (184.14.168.53):
In Reply to: oily distributor posted by fredmich on September 19, 2014 at 05:09:31:
Its a o ring and the pin is a drive out after removing a swelled end. Have used a rod the right size cut to length for a replacement pin. Shaft removal is needed to replace, so the point plate and a few other parts are removed to slide it out. But that o ring is not made to stop a bunch of oil. If it has a hydraulic pump in front of the distributor its probably the problem. If no hydraulic pump there was a serial number break on the ignition drive housing. After break a seal was used on the drive shaft and before that no seal. Even the ones without the seal usually didn't give a problem. Mite check to see if someone used oil instead of grease in the distributor gear housing.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
