Re: Marvel Mystery OIl
Posted by old on September 19, 2014 at 09:10:21 from (209.86.226.40):
In Reply to: Re: Marvel Mystery OIl posted by DoubleR on September 19, 2014 at 09:03:37:
ATF is in fact an oil that has qualities of cutting rust and freeing up stuck parts and in your case to lube the upper parts of the engine and clean out carbon build up and free up the piston rings
