Re: simple hydraulic question
Posted by D Slater on September 19, 2014 at 16:53:08 from (184.14.168.53):
In Reply to: simple hydraulic question posted by ellis kinney on September 19, 2014 at 13:07:29:
No the left rear port isn't a delay on lifting unless a delay lift valve is used in the line to hydraulic cylinder. When lowering it does have a different check that releases. So they are correct that with two lines to matching cylinders use the front left with the right.
Won't notice the difference with a line from each compared to one.
