Re: collectable tractors
Posted by WOpp on September 19, 2014 at 17:59:29 from (64.68.9.247):
In Reply to: collectable tractors posted by boberjagel on September 19, 2014 at 05:32:42:
for high value tractors you might try to find 450 highcrop lpg. Only 5 were made??? another would be 600 gas only 39 made. On the newer side a 2 + 2 last one made 7488-7688??? only 16 made. If this is your choice. You will need a deep pocket
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
