Re: Marvel Mystery OIl
Posted by NNP on September 19, 2014 at 18:10:37 from (66.66.112.196):
In Reply to: Marvel Mystery OIl posted by DoubleR on September 19, 2014 at 07:32:20:
sure go ahead, won't hurt anything.
I use MMO, ATF, Seafoam, in the gas only. Oil pans only get good oil.
Whatever I have laying around, in old tractors I get that I'm not going to tear down.
My highly scientific test that it works.....
When I use it in the gas on vertical exhaust tractors, my hood gets dirty with black specks.
Whether the black muck comes from the chamber or the inside of the exhaust system...who knows.
It was in the engine someplace...now it's not.
I see real mechanics pull in Seafoam thru a vacuum line to clean stuff, and pretty much everybody dumps a can of fuel injector cleaner in the tank of their modern cars once in a while.
same difference, right?
This post was edited by NNP at 18:14:36 09/19/14.
